Wheels
Visalia, CA, USA |
Registered on 1/20/2003 |
214 posts |
Posted:1/23/2003 09:32 |
When I leave a stop sign (or from a complete stop) under normal acceleration I hear and feel a clunk. It sounds like it is coming from the rear end, but I don't know. If I idle away from the stop for about 5 - 10 feet, then accelerate VERY slowly the clunk won't happen, but under normal or hard acceleration it is there. Has anyone else had this problem? I am going to take it to my transmission guy, but I just wanted to ask. |
gearman
los Angeles, CA, USA |
Registered on 1/22/2003 |
336 posts |
Posted:1/23/2003 11:28 |
i would like to know more info on the truck,(4x4,mileage,when did it start)sounds to me like its driveline wind-up which happens a lot to trucks ,especialy 4x4s after a while.this is a weakening in the rear springs.sometimes they can be shimmed,sometimes they need to be replaced.if you would like to call me at the shop i will email my phone# and see if i can help
regards,mike
Subscriber since 1/1/2001 |
Atlanta, GA, USA |
Registered on 1/23/2001 |
2,229 posts |
Posted:1/23/2003 12:27 |
Quote: | When I leave a stop sign (or from a complete stop) under normal acceleration I hear and feel a clunk. It sounds like it is coming from the rear end, but I don't know. If I idle away from the stop for about 5 - 10 feet, then accelerate VERY slowly the clunk won't happen, but under normal or hard acceleration it is there. Has anyone else had this problem? I am going to take it to my transmission guy, but I just wanted to ask. |
Sounds like a ujoint or the slip yoke in the driveshaft to me. If either of these are bad, you'll have a little "play" in the drivetrain so when you first take off quickly, you'll hear a "clunk" sound.
The tranny guy will get things squared away for you. Let us know what it was when you find out!
Wheels
Visalia, CA, USA |
214 posts |
Posted:1/23/2003 13:06 |
Quote: | i would like to know more info on the truck,(4x4,mileage,when did it start)sounds to me like its driveline wind-up which happens a lot to trucks ,especialy 4x4s after a while.this is a weakening in the rear springs.sometimes they can be shimmed,sometimes they need to be replaced.if you would like to call me at the shop i will email my phone# and see if i can help
regards,mike |
Thanks Mike...I will send you an email with the info. Or call you.
Jason |
