Replacement of side view mirrors
Thread Statistics:     Users to Post: 6   |   Total Posts: 12   |   Total Views: 3328
james j
• san diego, CA, USA
• Registered on 4/12/2004
• 11 posts
Posted:4/12/2004 18:42
I have a 00 X , 7.3 psd, Limited 4X4. I want to replace the original side view paddle style mirrors (power) with towing mirrors (extendable type). The question is how difficult is it to remove the old mirrors and replaced with the towing mirror assemblies, and where can I buy the towing mirrors other than the dealer? Any advice and instruction will be appreciated. JJ
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:4/12/2004 20:12
I see the mirrors on EBay on a regular basis.
//bruce
LANDYOT  SuperMotors Member
Subscriber since 11/23/2003
Posted:4/12/2004 21:03
Skip Ebay and go straight to the parts manager that sells them on Ebay. Scott Hart at Buckeye Ford in Ohio (do an online search for his e-mail and/or 800 phone number), or you can e-mail me and I'll give you his e-mail address (don't want to post it here ... causes spam).
Scott includes a wiring diagram for the T-T mirrors. It's fairly easy to figure out. You will have to run an extra wire to each mirror from the dashboard light switch if you want the type that has the integral running lights. I didn't bother with the wiring connection adapter, and spent more time soldering in some trailer-type disconnect-plugs than I did to install them in the doors.
james j
• 11 posts
Posted:4/13/2004 13:06
Landyot, I would like to email you, but since I am new on this forum I can not find your email address. Please point me the direction. JJ
james j
• 11 posts
Posted:4/14/2004 16:56
Called Buckeye Ford, and I was quoted by Scott for the set of replacement miirors (power and heated) of $ 279.00 + 25.00 shipping. Is that a good price?
James J
Posted:4/15/2004 16:25
James J -- To e-mail a forum user, simply click on their username to obtain an e-mail address (if the user has allowed others to see it ... and I see your e-mail address is not available). I don't have the part numbers for the T-T mirrors I bought. They are the remote-control / heated / integral-turn-signal / integral-running-light type that were selling on Ebay (from Scott) for $400 (shipping included). My local parts guy could match Scott's price, but the free shipping AND no sales tax aspect got me to buy from Scott. BTW, welcome to the forum. My old mirrors were the dog-ear style (I've heard some refer to the T-T as moose ear mirrors) with remote, heat & turn arrows. I like the turn signals on the T-T mirrors better because I cannot see them from the driver's seat when they're flashing. The running light feature is pretty cool, too. Also, I cannot say whether the price you were quoted is fair or not.
edited 4/15/2004 16:29
Doug Loper
• Byron Center, MI, USA
• Registered on 9/26/2003
• 114 posts
Posted:4/16/2004 22:31
As for removing mirrors this is from service manual.
Disconnect the battery ground cable; refer to Section 414-01 .
Remove the front door trim panel; refer to Section 501-05 .
Section 501-05 Remove the rear view mirror mounting hole cover.
If equipped, remove the window regulator handle.
If equipped, remove the window regulator switch plate.
If equipped, disconnect the power windows, power door lock switch and power mirror
connectors.
If equipped, remove the front door trim panel reflector or the courtesy lamp lens.
Remove the screws.
NOTE: Remove the front door trim panel (23942) by pulling it straight upward.
Lift and remove the front door trim panel.
If equipped, twist the courtesy lamp connector one half turn and remove it from the front
door trim panel.
Installation
CAUTION: Insert the lower panel tabs first or they can break when installing the front door
trim panel. Follow the removal procedure in reverse order.
Remove the front door watershield; refer to Section 501-05 .
Remove the mirror sail cover to gain access to the mirror retaining nuts.
Remove the outside rear view mirror (17682).
Disconnect the power mirror electrical connector.
Disconnect the power mirror wiring clip.
Remove the outside rear view mirror nuts.
Remove the outside rear view mirror.
Feed the power mirror wiring through the opening in the front door.
Installation
To install, reverse the removal procedure.
2000 X V-10
Mods: 6" Revtek lift
35" M/T Baja Claw Radials
16" x 10" Eagle Alloy Rims
SilverStar 9007
Clear front corners.
edited 4/16/2004 22:39
Daniel liguori
• Registered on 11/29/2003
• 19 posts
Posted:4/18/2004 03:37
James I just did this last week (twice because they sent me two lefts and I didn't notice until I did one and a half sides) I'll give you the abridged version of the instructions. Take the cap off above the doop panel right by the mirror(it just pulls off). Pull the two rubber plugs off right next to the plastic cap. Now on the door pannel pop the window controls pannel up, it too just pops off. Disconnect the harnesses to your controls. You will the a small screw now, take it out. Now pop the door light lense off. Now you see another screw. Take it out and lift the whole door pannel off but don't move it too far because you need to twist the light fixture out of the pannel. Now that's out of the way. Take the speaker out and unhook it's harness. Unplug the other two harnesses which connect to your mirror. one is small, rectangular and red, and the other is white and round. Now unbolt the mirror and pull that old piece of junk out of there. Do the same thing in reverse and be sure to test the power before putting everything back together.
BY THE WAY. I bought the non-oem mirrors and they don't have a defroster on them I live in San Diego so I could care less but if you live in the cold you might want to spend the extra 40 bucks for the oem version. Also keep in mind that the new ones are gonna give you a headache at first because they bounce a lot more than the paddle mirrors. Sorry for the lenghty reply but hopefully this will help...if you haven't already done this mod.
Daniel liguori
• 19 posts
Posted:4/18/2004 03:39
Well I guess that's really not abridged! I forgot. Make sure you take extreme care not to drop a bolt when removing the mirror because I would imagine it could be difficult to find. GOOD LUCK!!!
Posted:4/18/2004 09:51
Daniel -- You said you installed non-oem mirrors, and you have "bounce." My Ford T-T (moose-ear) mirrors I installed to replace the paddle (dog-ear) mirrors do not bounce at all. Solid as a rock. Maybe you could tell us who made your non-oem mirrors so that others could avoid them (in order to avoid the "bounce.")
