Mark Peterson
Big Lake, MN, USA |
Registered on 12/29/2004 |
25 posts |
Posted:1/4/2005 00:03 |
So the batteries are still completely dead. I went to plug the block heater in for the night and it
started sparking and smoking! What the heck is going on?
Mark |
 Subscriber since 1/1/2001 |
Atlanta, GA, USA |
Registered on 1/23/2001 |
2,229 posts |
Posted:1/4/2005 00:41 |
Quote: | So the batteries are still completely dead. I went to plug the block heater in for the night and it
Mark |
The block heater cord may be corroded and it is shorting out on your frame or some other piece of metal. Can you take a look at the cord and see if there are any cuts or worn spots in it?
Plano, TX, USA |
Registered on 7/24/2002 |
1,800 posts |
Posted:1/4/2005 07:56 |
As Eric stated give that block heater cord a close inspection as I've seen a few other Powerstroke powered trucks go up in flames(2 last winter) resulting from the cord
Mark Peterson
Big Lake, MN, USA |
25 posts |
Posted:1/4/2005 23:15 |
Thanks guys, I did inspect the cord and found a small slice. I taped it up, and plugged it in, and it
keeps tripping my GCF Outlet! Any More advice? Replace the whole cord? The last response about
2 in flames scares the hell outta me!
Plano, TX, USA |
1,800 posts |
Posted:1/5/2005 11:10 |
Mark,if a replacement cord is available thru fordpartsonline.com I'd purchase it
I haven't traced the path the cord going from the block to the front but if you can put a protective sleeve over the cord that might help prevent future chafing
Kelver
Weidman, MI, USA |
Registered on 12/7/2004 |
5 posts |
Posted:2/7/2005 19:10 |
Lost 5 in 2 months in my area all from bad cords. Seems they have a problem at the plug. Molded plug grrrr. Mine sparked and smoked but got it unpluged before the local FD got number 6. |
Plano, TX, USA |
1,800 posts |
Posted:2/7/2005 22:25 |
Quote: | Lost 5 in 2 months in my area all from bad cords. Seems they have a problem at the plug. Molded plug grrrr. Mine sparked and smoked but got it unpluged before the local FD got number 6. |
Stop by Home Depot and pick up a heavy duty plug to hardwire in then wrap up the wire with some electrical tape or something alike to protect the wire.
shiepo
carson, CA, USA |
Registered on 6/23/2011 |
75 posts |
Posted:7/21/2011 19:35 |
Quote: | So the batteries are still completely dead. I went to plug the space heaters in for the night and it started sparking and smoking! What the heck is going on?
Mark |
hi apology for making this thread up! the gas furnaces don\\'t work when electricity goes off because of the ignition and fan. In cold climates there is a need for a back up heat source. Can anyone recommend a supplier of it? |
