Rear end lift ideas?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 467
Bandit
• Austin, TX, USA
• Registered on 8/10/2005
• 38 posts
Posted:10/26/2005 17:48
OK. I have a 28' Airstream that weighs about 7800lbs dry, so wet I'm probably pushing 8500lbs and tounge weight of 950ish...
I put her on the back of my excursion, using a Equal-i-Zer hitch (WD and Sway control all in one) and she squated the rear down pretty good. I adjusted by WD bars and rasied the shack, so my squat is minimized, with about 1/2 in the front and 1&1/2 in the back. This is the best I could do.
So, I'm thinking I need to get a little rear end help... I thinking add a leaf / helper springs / air lift bags /etc.
I figure I need to raise the rear about 1&1/2 to 2 inches max for towing.
Anyone have any recomendations?
(I've aready changed to Rancho 9000s all around, dialed in a 7 when I tow with tires at 75 psi, and installed the Hellwig rear sway bar).
Kevin
docgas63
• Sugar Land, TX, USA
• Registered on 8/20/2005
• 37 posts
Posted:10/26/2005 18:36
Same problem (see my signature),
added a leafspring, (rancho add a leaf). Added about 1.5 inches, 500 lbs of tow capacity and now with my tongue weight of 950lbs, I am level.
Very easy, quick, no hassle.
DG
David, Sandra and 3 Kids
2005 4x2 6.0L PSD Excursion Limited
Sunnybrook 3310
Hensley Arrow - Prodigy
SuperChips, X-Monitor, Zoodad, PSD Badges
