short79572
staten island, NY, USA |
Registered on 8/7/2005 |
12 posts |
Posted:12/26/2005 16:03 |
was up i just waned to know if any 1 knows what the biggest tire i can put on my 2001 x 4x4 stock ride hight i herd i can put 305 70 16 just wantto know if this is right thanks guys |
Newport News, VA, USA |
Registered on 7/15/2003 |
1,110 posts |
Posted:12/26/2005 18:20 |
Welcome to the "X Files!"
I am running 305-70R-16 (load range E) Nitto tires on my 2001 4WD with no lift. The only rubbing I get is on the plastic splash panels on the aft side of the front fenderwells ... and then only when hitting a bump at full-lock, like entering my parking garage at work. You'll need to getter rims wider than the OEM 16x7. I bought a set of 16x8 rims on Ebay. Just be sure that whatever rim you end up buying has the same, or very similar backspacing. |
short79572
12 posts |
Posted:12/26/2005 19:29 |
i do not see why i whould have to change the rim it is a 16 inch rim right |
1,110 posts |
Posted:12/26/2005 19:37 |
Quote: | i do not see why i whould have to change the rim it is a 16 inch rim right |
If you have stock rims, they are 16" diameter by 7" wide. The minimum specified width for the 305-70R-16 tires is 8". Some folks have put em' on 7" rims, but I think it's wise to stay within specifications. Some tire shops will not mount them on 7" rims for fear of lawsuits. |
