Bill Johnson
Rio linda, CA, USA |
Registered on 6/11/2002 |
201 posts |
Posted:1/20/2006 17:15 |
Ok, my running board lights fill up with water. Anyone else have this issue? My sockets rust out so I have to replace them about once a year. Anyone have a fix for this?
Yahoo IM - kingsuv00
scott young
Lexington, KY, USA |
Registered on 9/30/2004 |
29 posts |
Posted:1/20/2006 19:32 |
Bill,
I have an 02 Ex V-10 that had the same problem. Mine was still under wtty so I took her to the dealer and they replaced the socket assy, lamp assy and the bulb assy. So in essence, they replaced the lamp housing, sockets and bulbs. I did notice no more leaks as it has almost been 1 year. They put some type of sealant around the lamp housing that goes into the running boards. My feeling when one my bulbs goes bad and I try to break the sealant, I'm going to have the same exact problem again.
Scott |
Eddie Henson
Cordova, TN, USA |
Registered on 12/8/2004 |
122 posts |
Posted:1/20/2006 23:41 |
How about trying some plumber's putty and placing a small bead around the base before putting the lens on. Press the lens in place and use a putty knife to remove the excess. Stuff nefer hardens and provides a water tight seal. Just a thought.
Eddie Henson
"If you don't like America, Get the hell out !!" - John Rich |
sponger_2
san jacinto, CA, USA |
Registered on 1/9/2006 |
6 posts |
Posted:1/22/2006 02:40 |
that or silicon |
Bill Johnson
201 posts |
Posted:1/22/2006 11:00 |
I was thinking of that. it seems like it's got a good seal around the base. It's pretty good at holding the water in. when I get a good day to wash her, i"ll seal them up
shiepo
carson, CA, USA |
Registered on 6/23/2011 |
75 posts |
Posted:11/22/2011 18:16 |
Quote: | Bill,
I have an 02 Ex V-10 that had the same problem. Mine was still under wtty so I took her to the dealer and they replaced the socket assy, lamp assy and the bulb assy. So in essence, they replaced the lamp housing, sockets and bulbs. I did notice no more leaks as it has almost been 1 year. They put some type of sealant around the lamp housing that goes into the running boards. My feeling when one my bulbs goes bad and I try to break the sealant, I\\'m going to have the same exact problem again.
Scott |
hi scott where did you bought your running board? ive been looking for it but i dont know where can i find a perfect one. please help me on this. |
