Anyone have any issues with one or both of the windows not wanting to open? I've had it before where they wouldn't open but after several attempts would work. Now my pass side one will not open at all. I hear something when I push the button, like the little servo is trying to run but it won't. The driver side works fine most of the time, but still occasionally won't open on the first try. Any easy fixes? Any suggestions?
if your servo is working....
The first thing to try is that the heat and cold cycles will make the gasket "stick" to the window and make it too much force for the servo to work....
have someone open the window while u give a slight pull to help it...
then lubricate the gasket so it won't stick and that should help....
