Rear Vent Window
Thread Statistics:     Users to Post: 10   |   Total Posts: 21   |   Total Views: 4365
Phillip Beall
• Honey Grove, TX, USA
• Registered on 11/7/2004
• 74 posts
Posted:1/21/2007 22:03
Folks,
At http://www.supermotors.net/forums/thid-5910-2001-excursion-vent-windows#31582 a forum member ronbus1 started up a thrad entitled "2001 Excursion vent windows" last year and never got a reply. I have had the same issue and am going to search this forum and see if I can find another source for the answer and see if there is any discussion of it. If one of the moderators could merge the thread into this one it seems most appropriate to have it here in the Excursion generic discussion area. I'll also send ronbus1 a note and point him to this post to hopefully get him started toward his answer. Just in case his preferences don't allow members to contact him if a moderator might like to do the same I'm sure he would appreciate it.
Regards,
Phil
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:1/21/2007 22:08
Mine has been spotty when it is cold. Now that I have a new motor for the left side in hand, the motors are scared of being replaced and seem to work fine.
housedad
• mt royal, NJ, USA
• Registered on 10/8/2005
• 88 posts
Posted:1/21/2007 22:20
Sounds like the motor has gotten thermally sensitive. The cause for that is heat breakdown of the insulation on the motor widings, for example. Other causes could be a connector that bends out of place when hot and expanded, and breaks the electrical contact. I have seen one common spray lubricant that has different dielectric properties between normal and hot temperatures, so even the wrong lubricant can come into play.
NASCAR-Mike
• Richmond, VA, USA
• Registered on 9/14/2005
• 20 posts
Posted:1/22/2007 06:30
Mine were sticking during the hot and cold and it turned out that the rubber seal was stuck to the glass.
I brought to the dealer and they applied rubber silicone tratment to the rubber seal and now it works all the time, hot or cold.
2005 Ford Excursion Eddie Bauer 6.0 diesel
1996 Ford Crown Victoria P74
1994 Ford Mustang GT 5.0 SUPERCHARGED
ronbus1
• Ft. Wayne, IN, USA
• Registered on 7/23/2006
Posted:1/22/2007 07:06
Thanks for the help with the rear vent windows.my computer skills are primative!!!RONBUS
housedad
• mt royal, NJ, USA
• 88 posts
Posted:1/22/2007 07:46
Absolutely amazing how many ways things can go wrong!!
LANDYOT  SuperMotors Member
Subscriber since 11/23/2003
Posted:1/22/2007 18:22
I believe the owner's manual specifies lubricating those window gaskets, along with all of the door weatherstripping, every 6K miles. It's the only time I use Armorall ... just dampen a rag, and wipe the rubber. Lemon Pledge will work, too since it has a lot of silicone in it.
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:1/23/2007 21:53
Mine will stick when I haven't used them in awhile.
Yahoo IM - kingsuv00
GOT8KIDS
• Rosemount, MN, USA
• Registered on 2/10/2005
• 19 posts
Posted:1/25/2007 13:03
My 02 has had a problem with the rear windows for some time. It does not matter if it is hot or cold out. They are not stuck to the gasket either. Sometimes one works and the other does not. It does not matter which. Sometimes both do not work and sometimes they both work. When they will not open I can hear a click coming from the back. So there is power back there and some component is not doing its job. When they do work the motors sound fine. If they do open I will not leave them open for fear they will not close when I need them to.
02' X V-10, Limited, 3:73, Stainless hood shield, DVD
Phillip Beall
• 74 posts
Posted:1/25/2007 19:46
GOT8KIDS,
Yeah, that's more like ours. I've siliconed the seals and haven't concluded that it really makes any real difference. It [u]may[/u] be worse when they're hot, but that too doesn't really seem to be the key...
We've found that if we go back and forth on the switches (rocking them to the open and then the closed position) when they're acting up, that oftentimes will get the windows to suddenly come open.
I'm really thinking there's something up with some sort of inconsistent relay, probably heat induced, but I was hoping someone with some magic bullet might chime in. Hopefully someone still will.
Phil
Rear Vent Window
