Door sensors
Thread Statistics:     Users to Post: 4   |   Total Posts: 7   |   Total Views: 863
Yevgeniy Misyuk
• Hermiston, OR, USA
• Registered on 12/19/2004
• 9 posts
Posted:5/13/2007 17:20
I have a 2001 Ex PSD. Lately the door light stays on (and I checked that all the doors are shut) I cannot find any manual switches in the door jams. I figured there have to be magnetic ones or something. Anyone has any ideas what to do? That light drives me nuts... Thank you.
Jay Hanratty
• Millbury, MA, USA
• Registered on 8/13/2004
• 35 posts
Posted:5/13/2007 19:05
Hi
I went through this same thing three years ago, a Ford Technical trainer showed me the fix. The switches are part of each door latch.
Open the door and take a aerosol can of white lithium greese with a long thin nozzle, insert in down inside the latch spray a liberal amount down iside, open and close the door a few times then with it closed the light should go out, if not move onto the next door and repeat. You'll know which one was the culprit when the lights go out. Lube all the door latches including the rear hatch and half doors on a regular basis and it will keep the interior lights working properly. I do this twice a year and haven't had the issue with the lights since I was shown the trick.
• 1,800 posts
Posted:5/13/2007 20:13
I hit the latches with Silicone spray,it works very well also
Yevgeniy Misyuk
• 9 posts
Posted:5/14/2007 13:13
Thank you all for the fast response. I will go to the store today and get the silicone spray. I will let you know how it went.
Yevgeniy Misyuk
• 9 posts
Posted:5/27/2007 18:32
Hey guys, thanks for you help. I lubed all the doors and don't have any problems any more. This forum is the best!!!
• 1,800 posts
Posted:5/27/2007 18:35
Glad to know it worked out for ya!
Yes for Excursions this is the place to go
Ace
• Malibu, CA, USA
• Registered on 10/27/2005
• 54 posts
Posted:7/13/2007 15:20
I had the same problem, got a can of graphite spray for locks and sprayed the hell outta the back door latches...did the trick
Door sensors
