lawman1989
Perry Hall, MD, USA |
Registered on 2/13/2005 |
18 posts |
Posted:9/27/2007 16:04 |
My X had a fair amount of vibration at 40,000. I decided to change the front brakes due to all the warp issues with the X. This was my first time doing this with my truck. I was surprised to find that only about half the pad was used, I expected more wear. I took the rotors and had them turned. Bought new pads which were hard as heck to get in with those darn springs.
Made it easier by wraping a rubber band around them to get them in the caliper. After all is said and done I still have soem vibration at higher speeds when applying brakes. I think the rotors are still a little warped.
Are the ART rotors that good or can I find a pair at a local shop? |
poormonkey
Chicago, IL, USA |
Registered on 7/27/2004 |
59 posts |
Posted:10/1/2007 10:17 |
When I did all my brakes, I replaced the rotors with Ford Motorsport rotors. I got a good price through a local parts store, and I haven't had any vibration issues at all. ART might make a better rotor, but their price is a lot higher then what I paid for the FMS rotors....
2002 Excursion 4x4 7.3L |
lawman1989
18 posts |
Posted:10/3/2007 16:15 |
Thanks for the info, I will look into them. |
The Big Island, HI, USA |
Registered on 1/5/2002 |
1,056 posts |
2 Vehicles |
Posted:10/5/2007 15:29 |
If you don't feel it when you're at a slow speed then I doubt your rotors are "warped" (which is a myth BTW).
You may want to double check your ball joints. Worn ones will cause high speed braking vibration.
clubseal
Cherry Hill, NJ, USA |
Registered on 7/21/2005 |
1 post |
Posted:10/7/2007 08:08 |
Front brakes are a real problem since the change in '88. I've gone through 4 sets of Ford's best. Finally did some real research and bought Nascar type Perfomance Friction 2 part rotors. I have driven 100K on them and they are still awesome.
Todd |
Ian Robertson
Toronto, XX, Canada |
Registered on 10/16/2002 |
4 posts |
Posted:12/30/2007 16:15 |
Read a brake article for my ford SHO. Found out cheap rotors + cheap pads = rotor warp. Expensive rotors + cheap pads = rotor warp. Expensive pads + cheap rotors = no rotor warp. Expensive pads + expensive rotors = no rotor warp. Conclusions, spend your money on good pads, replace rotors with good [not the most expensive] rotors, DO NOT have rotors turned [takes out mass leading to quicker rotor warp] and season or bed new brake pads properly to get max trouble free life out of brakes. |
Mark Rychel
Chesterland, OH, USA |
Registered on 3/10/2003 |
54 posts |
Posted:3/15/2008 08:47 |
I changed to ART Rotors at about 50,000 after having the fronts turned once. I have been very pleased with the results. On my previous EX 2000 I had problems with warping after they were changed to factory rotors and did not want this to happen again.
With price of Diesel here, it looks like I won't be driving the EX as much, so i should get more years out of the rotors.
Mark |
rmwitt
gilroy, CA, USA |
Registered on 10/21/2007 |
8 posts |
Posted:8/16/2008 23:17 |
x03 owner:
I don't know if my rotors were wrapped, but i had bad vibration when braking hard or soft. With all i read, i decided to replace the rotors and brakes at 75k miles. i bought the parts at
http://brakeperformance.com/site/brake_rotors.php?&dv=0408&ad=google
slotted and drilled - They work great -- no vibration when braking, and very smooth, solid braking. |
shiepo
carson, CA, USA |
Registered on 6/23/2011 |
75 posts |
Posted:2/16/2012 01:18 |
Quote: | My X had a fair amount of vibration at 40,000. I decided to change the front brakes due to all the warp issues with the X. This was my first time doing this with my truck. I was surprised to find that only about half the pad was used, I expected more wear. I took the rotors and had them turned. Bought new pads which were hard as heck to get in with those darn springs.
where did you bought your brake? im planning to have one. please let me know asap. thanks. |
