fattrout1
chippewa lake, OH, USA |
Registered on 8/5/2009 |
3 posts |
Posted:8/5/2009 14:34 |
I have a 2000 Excursion, all of the sudden the front breaks started smoking. I replaced the pads and put a rebuild kit with v-springs and new slides, this has not helped.
I was told by a local auto parts store to replace both front calipers. Is it possible both sides go out at once? I don't think that is the problem, any suggestions?
Any comments/suggestions on this problem would be greatly appreciated!
Thanks in advance. |
The Big Island, HI, USA |
Registered on 1/5/2002 |
1,056 posts |
2 Vehicles |
Posted:8/5/2009 23:02 |
Do your brakes work? Does it pull to one side? Does the smoke smell like brakes or burnt fluid?
fattrout1
3 posts |
Posted:8/6/2009 20:49 |
yes the breaks work, and it smells like burnt rubber. No it does not pull just a shaking steering wheel like the pads are stuck to the rotor. And it runs at a higher engine RPM.
One time it does this instantly and the next it is fine for a mile or so then starts.
thanks for any suggestions! |
David Rush
Greenville, SC, USA |
Registered on 4/11/2004 |
233 posts |
Posted:9/27/2009 20:05 |
I guess it could be something to do with the ABS. The shaking in your steering could concievably be due to the ABS pulsing as it does when you have a hard stop.Sounds like your brakes are locking and if your rpm's go up-something is telling it to either down shift or to increase engine rpms. I would be more inclined to think electronics could be a problem. That's just shooting from the hip.. Have you used an OBD tester to see if there's a code??? |
shiepo
carson, CA, USA |
Registered on 6/23/2011 |
75 posts |
Posted:6/16/2012 02:09 |
Quote: | I have a 2000 Excursion, all of the sudden the front breaks started smoking. I replaced the pads and put a rebuild kit with v-springs and new slides, this has not helped.
I was told by a local auto parts store to replace both front calipers. Is it possible both sides go out at once? I don\\\\'t think that is the problem, any suggestions?
hi dude what is the name of the car parts online store did you buy your parts? im planning to buy parts and i was confuse on where to buy them. please help me on this. thank you. |
