94 f150 window motor help
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1317
gtanner6094
• tyler, TX, USA
• Registered on 11/16/2014
Posted:11/16/2014 06:09
looking for some instructions on replacing window motor. motor will run just not raise or lower glass, any tips on fixing, thanks.
pdmoney
• rocky point, NY, USA
• Registered on 12/16/2009
• 8 posts
Posted:11/30/2014 14:44
Good luck, looks like these forums have been taken over by SPAMBOTS!!
Sounds like your tracks came off or the gears are stripped on the motor. If the motor is working but no movement, something else is broke! Its always hard to get inside a door to see whats going on...gotta taje door panels off and stick a flashlight in there...small hands work best!
BigDangFord
• Chandler, AZ, USA
• Registered on 3/11/2015
• 42 posts
Posted:4/19/2015 15:24
what happens is the drive is fubared. you can remove and fix easily. it take 3 dowels about 7/16 in diameter and about 1/2" long each.
take the gearbox apart and replace these. i used plastic rod.
