interior lights and back windows
Thread Statistics:     Users to Post: 3   |   Total Posts: 7   |   Total Views: 448
p71guy77
• new bedford, MA, USA
• Registered on 12/23/2014
• 7 posts
Posted:12/23/2014 19:50
I have a 01' crown vic p71 with no interior lights and the back windows do not work. Does anyone know how to reactivate them?
XBOMMAN
• HURLOCK, MD, USA
• Registered on 11/26/2014
• 15 posts
Posted:12/24/2014 06:37
Check and make sure that the fuses are in the fuse panel under the left side dash. If they are, check and make sure that they have power to them with a test light.
If they don't have power to them then check both of the power boxes in the glove box and if not, then go under the hood and check the power supply boxes on the right front wheel well. And if that does not have power then they either need new relays or fuses, or to be re-connected to the battery.
Remember to check the fuses at each stage of your checking the power at each point in your search, and make sure that the fuses are good.
p71guy77
• 7 posts
Posted:12/24/2014 10:36
Do you know which fuse it is for the windows? I don't have a diagram. Do you think the light issue could be the "dark mode" setting?
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:12/24/2014 14:00
I never understood why people start 5 different threads for one single problem...
XBOMMAN
• HURLOCK, MD, USA
• 15 posts
Posted:12/25/2014 07:38
If you go to WWW.FORD.COM, you can find the fuse locations and sizes in their owners manual section. An entire owners manual can be viewed at that location also. They also have a section listed for CVPI vehicles that gives wire and fuse locations.
Just click on the owners manual and go to the appropriate section for the fuses, and then the same for the police duty wiring.
There is also a site for CROWN INDUSTRIES that handles a lot of the equipment put on the CVPI vehicles.
Hope this helps, Merry Christmas! (Even to those who can't help but be critical of certain posts or their numbers)
p71guy77
• 7 posts
Posted:12/25/2014 08:26
It was an accident. When i was posting it didn't appear to go through.
p71guy77
• 7 posts
Posted:12/25/2014 08:28
Thanks, i'll try that. Merry Christmas
