Forums > SuperMotors Topics > SuperMotors Support & Suggestions
1992 Crown Victoria wont start
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 819
92crownvictora
• Richmond, VA, USA
• Registered on 3/16/2015
Posted:3/16/2015 18:11
I am working on my 1992 Crown Victoria that will not start. It turns over good with a new battery. I have changed the fuel filter and plugs. I have sprayed started fluid down the intake to see if it will start and it does not do anything. I have pull the spark plug wires on each of the 8 wires and put a spark plug next to the block and turned the car over. Each plug sparked next to the block. I am unsure what to check next. Could it be the crankshaft position sensor? I am pretty much out of ideas what else to check on the car. Any help would be greatly appreciated. Thanks
BigDangFord
• Chandler, AZ, USA
• Registered on 3/11/2015
• 42 posts
Posted:4/19/2015 17:20
sounds as if you do have spark and probably at the right time, maybe you can crack a fuel line open and see if you have pressure right at the top. cycle the key several times, do you hear the fuel pump run and shut off?
