1999 ford crown vic power window fault
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 592
eli692
• fort sill, OK, USA
• Registered on 7/26/2015
Posted:7/26/2015 20:00
I recently replaced the driver window regulator and motor, after installing the new regulator and motor, when pushing the down auto button the motor will keep rolling even when the window reaches the lowest position, when pushing the up button the window motor will also keep rolling after the window has hit the highest position, this will eventually lead to breaking the cable.
at some point I did jump start the car.
any ideas of why this is happening ?
thanks in advance
eli
danang44
• Balikpapan, SD, Vietnam
• Registered on 8/21/2015
Posted:8/21/2015 22:14
seems hook, which is at the bottom of your car window, so the window padawaktu lowered down or raised up to touch the wires on the bottom of the window. So you fix the cable hook the cable so that there is in the window can be attached tightly in place
Jasa Seo Termurah | Paypal Balance Terpercaya
