09 P71, turbos or supercharger?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 844
LuvMyP71
• Snowflake, AZ, USA
• Registered on 9/6/2015
Posted:10/2/2015 17:14
So i guess im just curious wither people perfer superchargers over turbos. I want to supercharge mine, but i was at the shop today and my mechanic made a good point. Supercharger driven power.... Turbo-- free power. So tell me people, turbo or supercharger?
Posted:10/3/2015 11:24
Turbos VS Superchargers has been a debate for years. And each has its own advantages and disadvantages.
Supercharges are either mounted directly to the engine or hang off the engine (centrifugal). They are all belt driven and do use some engine power to produce power. With a SC, you get low end torque quickly.
Turbos hang off the engine (similar to centrifugal SC's) The complexity of building an exhaust system to pass all the exhaust through the turbo is time-consuming and expensive. A turbo needs time to spin-up to build pressure to build power. this is called turbo-lag. So a turbo must be small enough to reduce this lag. If the turbo is too small, it limits your power. If its too big, you get little or no power until you hit a particular rpm range.
And then there are people who put both on an engine to get big power through the entire range. And others who have put dual turbos of different sizes for a wider range of power.
I would go to several Mustang forums and see what others have done. You may find something you like and prefer. IMHO I would use a Kenne Bell 2.8 SC for nice all around power. http://kennebell.net/KBWebsite/Home_pg/layouts/Homepage.htm Give them a call and they can help set you up with a sc kit that almost appears to be stock on a P71.
edited 10/3/2015 11:28
