MattyBees
Kekaha, HI, USA |
Registered on 7/14/2016 |
8 posts |
2 Vehicles |
Posted:7/21/2016 22:57 |
Can't find my other thread posted here so starting another.
1999 CV cranks but won't start.
All fuses and relays good.
Fuel pump does not come on when key is turned on, but works if jumped through relay.
Everything works: lights, radio, fan, ect.
***When key is turned to start the Engine light does not come on****
***When I hook up an OB tester it reads ERROR***
Inspected the wiring harness under bumper and looks good.
Started when I sprayed starting fluid into intake. |
plstktnkr2
Reisterstown, MD, USA |
Registered on 7/27/2011 |
13 posts |
2 Vehicles |
Posted:7/22/2016 04:56 |
When you jumped the relay, did the car start? it Just a thought. It could be the initialization wire in the PCM circuit or PCM itself.
1966 Lincoln 'vert
1985 Lincoln Hearse
1983 Mustang 'Vert |
curemode2002
Lehi, UT, USA |
Registered on 3/8/2012 |
147 posts |
Posted:7/22/2016 07:55 |
The 99s have the fuel shutoff switch in the Trunk. If you triggered this at all that could be your issue, the switch is on the Drivers side of the trunk under the felt mat. The Red push button switch should be pressed in. |
MattyBees
Kekaha, HI, USA |
8 posts |
2 Vehicles |
Posted:7/26/2016 16:28 |
I did check the fuel inertia button and it's good.
When I jumped the fuel relay, pump worked but car did not start.
It did start couple times early on with starting fluid but now won't start.
It's got to be the PCM ya? Anyone know where to get another PCM? I'm in Hawaii.
Should have added the original stoppage of engine was due to a loose power wire going into the fuse box under the hood due to stripped nut. This was sparking randomly causing stoppage prior to completely killing engine. I repaired the stripped bolt/nut then had the no start condition in original post.
Thanks plstktnkr2 & curemode2002 for your responses! |
curemode2002
Lehi, UT, USA |
147 posts |
Posted:7/26/2016 16:44 |
Best bet for a new one is rockauto.com used I would hit ebay
