Posted:8/7/2016 08:19 |
Hey Im having issues with a truck i recently bought. The winshield wipers wont park when i turn them off, they stop at the spot where i shut them off. Is this a problem with the park relay? And if so, is it in the wiper motor itself or is it in the switch?
Any help would be great, cant seem to find a straight answer on any threads |
Posted:8/7/2016 11:22 |
It is not your wiper switch. Inside the wiper motor assembly is the switch to park the blades. Unfortunately you have to purchase a new wiper motor assembly. Or go to a junk yard and find the motor assembly from a wrecked F250. You might check to see if the motor assembly from a F150 will fit. Best of luck.
Posted:8/7/2016 14:08 |
I opened up the cover for the elctrical and cleaned it up, bent the contacts on the cover out a bit to ensure proper contact, put a little electrical grease in and put it back together. Works perfect now!
