Thread Statistics: Users to Post: 2 | Total Posts: 2 | Total Views: 342
Pages: 1
ant8669
charleston, SC, USA
Registered on 8/25/2016
Posted:8/25/2016 09:41
Hello first time poster,
So here's my problem my ac recently went out an after tinkering it wasn't getting any power so I moved another relay to its spot viola my compressor kicked on, I replaced the fuse to its position an kept the ac relay out and went to the parts store got an replacement use a diy charging system an my ac was lovley cold went in the house after I turned the car all the way off came out 5 mins later and now the compressor won't kick on even with the original relay I used to test it???
Is it possible one of the many other fuses related to the ac blew? It seem like a power issue?
It is possible another fuse has blown, but there is also a pressure switch that will not let the compressor start if you are too full or too empty. I would check the switch first. Also if the AC is not turning on you may have a bad leak in the system. Did you put in coolant with a dye to detect leaks?
