Crown Vic. Sensor Ref. Voltage 'A' Low : p0642
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 972
sadkowmx90
• Chicopee, MA, USA
• Registered on 12/5/2016
Posted:12/5/2016 10:12
I have a 2008 CVPI and I am getting the following 4 codes:
P0107 (MAP Sensor Signal Low)
P0192 (Fuel Rail Pressure Sensor Circuit Low)
P0452 (EVAP Pressure Sensor Circuit Low)
P0642 (Sensor Reference Voltage 'A' Circuit Low)
I am assuming that there is either a short somewhere or there is a problem with the ECM. How do I determine if the ECM is either good or bad ? Would anyone have a pin-out of the ECM and the voltage ranges of each pin ?
If my assumption about the issue is wrong, please chime in.
Gz6jjd
• Olathe, KS, USA
• Registered on 1/8/2019
Posted:1/8/2019 07:28
I know this post is old but I’m having the exact same problem with my Vic. Did anyone ever come up with a solution?
