Thread Statistics: Users to Post: 2 | Total Posts: 2 | Total Views: 901
Pages: 1
Kflorence299
Santa fe, TX, USA
Registered on 7/9/2017
1 post
Posted:7/9/2017 12:21
I have a Crown Victoria that occasionally would hesitate on starting and you would have to turn over and pump the gas a couple times check the switch checked found running off the battery cable with look like a ground but I'm not quite sure I have pulled the battery charged it it was a good battery I've been checking on tracing wires and I found what look like a cut ground I don't know but my car is dead to the world. Now while I was driving down the street one day the speedometer started jumping real bad couldn't tell how fast I was going or anything now I've had a couple electrical issues where the radio stations would jump my AC does not work and it I don't know why it only has a heater but now my car does absolutely nothing I have traced wires I checked fuses I checked relays any ideas under the sun
littlejay
Denver, CO, USA
Registered on 3/13/2016
Posted:8/2/2017 20:38
I've been having the gauge issue on my 2010, also my odometer is super dim. Also I have the cut ground, don't worry about that unless it's your only ground. From what I have been reading it's either the gauge cluster itself or the wire that goes to the overdrive off button on the shifter shorting out.
