Stopped running while driving
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 711
RetireK9
• Butler, PA, USA
• Registered on 8/8/2017
Posted:9/15/2017 13:33
I have a 2004 Police Interceptor with 126000 on it and new battery. Back in January was driving down the road at about 40mph and the car just shut off and I was coasting to a stop. All gauges shut down and was like someone pulled the key. I noticed earlier that day the car made like a sputter and than went back to normal. Now I did notice this also I have had the cats removed which had made my check engine light stay on all the time but since the car will not start now I noticed that the light will not even illuminate , which makes me think this may be an electrical issue. now I tried cranking it and after checking the spark plugs there is no fuel on them. So could the fuel pump make this to stop or am I looking at the wrong items. Someone if you know could you help, this was my main car for 5 years and I am lost with out it. Thank you.
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:9/15/2017 16:40
When you turn the key, do you hear the pump prime?
If everything(gauges and engine) just shut off then the fuel pump is not your main issue.
The PCM has a relay and fuse in the fuse box under the hood, see if those are ok if nothing is working.
Having the CEL on all the time can open a can of worms, if a new problem comes up you will never know unless you check why it's on every day.
RetireK9
• Butler, PA, USA
Posted:9/17/2017 13:33
I can not hear the fuel pump. I tried this on another Crown Vic and I could not hear it either.I did check the relay under the hood and every time the key is cycled the relay clicked. I have checked all fuses under hood and under dash.
