03 Ford Crown Vic
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1487
Ateam
• YUMA, AZ, USA
• Registered on 11/30/2017
Posted:11/30/2017 17:44
I Have an 03 ford crown vic. I let some people drive it and work on it. So the car started when I came to pick it up. It had a bad hesitation and the wire harness for the lighting and engine was completely damage. I replace bother harness. Lighting works perfectly. Engine harness does not give power to when ignition is turn on to injectors or coils. All fuse and relays are Good. I test power and ground habe both with engine off. When key is on ground but know power to fire the car. It does crank but won\\'t start and run. Any thoughts????
PJC1
• Nottingham, PA, USA
• Registered on 8/26/2017
• 7 posts
Posted:12/1/2017 08:04
Check the connection at the PCM
2002 MGM LSE 103k
1998 Ddoge Dakota 4x4 163k
Nola_Vics
• metairie, LA, USA
• Registered on 5/5/2018
Posted:5/5/2018 02:05
check connecrions and relays for your starter
03 Ford Crown Vic
