crown Vic engine swap
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1041
fletcher216
• Midlothian, TX, USA
• Registered on 2/3/2018
Posted:2/3/2018 15:34
Will a 2005 Mercury Marquis 4.6L engine work in a 98 Crown vic with a Romeo 4.6L
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:2/3/2018 17:22
Yes, it will work and it will be an upgrade.
The 2005 engine will be a "PI" engine while the 1998 is an "NPI".
If the CV is a P71, the other difference will be the oil cooler, but that can be swapped from the old engine onto the newer one.
2008crownPI13
• erie, PA, USA
• Registered on 8/10/2018
Posted:8/10/2018 23:21
Might have an issue as the 2005+ are drive by wire throttle control. I'll see what I can find but you may end up needing some wiring done besides the mechanical parts. Such as a 05+ pcm, having it matched to the car etc.. I did find this if it helps. https://forums.tccoa.com/7-engine-4-6l-5-4l/171170-crown-vic-engine-swap.html
edited 8/11/2018 00:43
