Thread Statistics: Users to Post: 2 | Total Posts: 2 | Total Views: 570
Pages: 1
Vicnation0620
Philadelphia, PA, USA
Registered on 7/7/2018
Posted:7/7/2018 12:17
Need some help crown Vic family. My air suspension jacked my rear all the way up, anyone know how I can level it back out??
2008crownPI13
erie, PA, USA
Registered on 8/10/2018
Posted:10/22/2018 07:27
Have your codes scanned it should be throwing one. It is most likely the exhaust function on the solenoid/s or compressor has failed. To change out the bags and solenoids I believe is currently $110 shipped including both air springs, o rings and solenoids. They also offer that plus the compressor including dryer for $278. Individually the compressor/dryer is $144 from suncoreindustries. I currently have an 2008 p71 which sits a bit higher and is firmer with its coil springs. I've had and ridden in several panthers however with and without the air springs. The air definitely rides excellent esp with added weight where ride and height is automatically adjusted. I wish they offered which would require much more robust ones, front air springs. How cost effective that would be to mass produce I couldn't not say. But look under most school buses and semi trailers and you'll see air springs they can handle heavy consistent loads.
