Forums > SuperMotors Community Discussion > Introductions
94F150 5.0/W EFI 4X4
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1224
BJREYNOLDS
• LITTLE FALLS, NJ, USA
• Registered on 4/30/2019
Posted:4/30/2019 20:07
BRIAN REYNOLDS HERE,
I'm having a bit of a problem and need some help. I'm not getting any oil pressure readings. I talked to friend and he said clean out the sender connection port. I did that and before re-installing the sending unit I turned over the engine to make sure oil was coming out. Well it was and a lot of it. This told me the port was clear and I cold re-install the sending unit after, I cleaned up all the oil. Started the engine and the pressure needle jumped about halfway up on the dial and quickly back below zero. I then checked the auxiliary gas tank and watched the needle go past the full mark and it only had 5 gallons of gas. I think I have an electrical problem but don't know where to start looking. I would greatly appreciate any advice. Thank you.
Carvy27
• Hinesville, GA, USA
• Registered on 7/9/2019
• 14 posts
Posted:7/17/2019 19:23
Howdy! That sounds a major issue. Try posting on the tech section here.
