Ford diveline issues/questions. please help!
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 699
Pete Morgan
• Calgary, XX, Canada
• Registered on 11/8/2003
Posted:11/8/2003 18:10
Hey guys, I'm new here. My name is Pete and I am asking for help.
I have a 1995 Ford F150 Super cab.
Anyways. my truck came with a Ford 8.8 Inch Dif with 308 gears. it has an AOD tranny and a 5.8L (351) engine. it also has rear ABS
Last night I decided to swap out the dif (it was howling a lot) for a 1976 Ford 9 Inch housing with 350 gears in it.
The conversion went really well, except for the fact that I have lost my speedometer and my O/D light is flashing. I also don't have ABS anymore but we were expecting that since the 9 Inch doesn't have ABS
Here is the problem I have run into: On my old dif, the ABS sensor and the speed sensor are one in the same. by removing ABS I removed my speed sensor.
This is my question: Can I bypass that sensor and run it straight though to the tranny (which is the AOD)? If so, how can I do this.
Here are some pictures of my truck. it's dorpped 10 Inches
http://www.cardomain.com/member_pages/view_page.pl?page_id=421396
Any suggestions or help would be greatly appreciated.
Pete
edited 11/9/2003 02:45
Frankenstien
• Buckley, WA, USA
• Registered on 11/9/2003
• 16 posts
Posted:11/9/2003 22:28
... Best get the old rear fixed replace the ring an pinion, ... I beleave you have an EoD4 tranny, the computor tells this when to shift ... it gets its info from at least 2 places, The TPS (throtel postion sensor) the Speed sensor from the rear...
