E4-0D vibration
Thread Statistics:     Users to Post: 3   |   Total Posts: 6   |   Total Views: 918
Don Stith
• New Orleans, LA, USA
• Registered on 2/5/2003
• 42 posts
Posted:2/6/2003 19:08
The E4-0D in my bronco is vibrating between 3rd and Overdrive. It's getting worse and i don't know what's causing it. Thanks in advance for any help.
Don
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:2/14/2003 16:13
sounds like torque converter clutch going bad.to check it,get the truck up to where it vibrates,try to hold that speed(keep the vibe going)lightly depress brake pedal with left foot(this electronicaly releases torque converter clutch)if vibe goes away then you have a bad converter
hope this helps, mike
Don Stith
• 42 posts
Posted:2/16/2003 21:07
Yup, I went out and tried it and while keeping the vibration going, as soon as i lightly depressed the brake pedal the vibration went away. Thanks, now all i've got to do is get my income tax refund so i can get another converter. $180 + fluids and filter. I'm doing the work myself. Thanks again. Don
gearman
• 336 posts
Posted:2/18/2003 16:54
just some advice from someone who has done hundreds of them,by a Ford reman.converter.that is all i have used in the last 11 years(except for the high performance)and have had 2 failures.previous to that,i was running 70% failure ratio on aftermarket rebuilts.
good luck,mike
ralph corvino
• Hollywood, FL, USA
• Registered on 8/28/2003
Posted:8/28/2003 17:50
hey guys, different topic but same trans, i have a 93 4x4 bronco and it chugs between 30 and 40 mph in drive. its lifted with 33's and i cant figure whether its the motor or trans,ive been doing city driving in second..
any input is greatly appreciated!
rcorvino@bellsouth.net
gearman
• 336 posts
Posted:9/4/2003 13:46
which trans do you have?
mike
E4-0D vibration
