Britt Lytle
High Point, NC, USA |
Registered on 10/31/2003 |
3 posts |
Posted:12/8/2003 09:50 |
I have a "rear antilock" light that occasionally comes on. I have an 88 full size Bronco but it does not have anti-lock brakes. Can anyone tell me what this is and if I should do anything about it?
Britt |
Joey Stokes
Marysville, WA, USA |
Registered on 5/14/2003 |
48 posts |
3 Vehicles |
Posted:1/6/2004 12:07 |
there is not much reason to worry about it, its tellin you that the RABS system had found a fult due during self test, mine come on every now and again also. |
Joey Stokes
48 posts |
3 Vehicles |
Posted:1/6/2004 12:08 |
i think its also worth adding that next time the light comes on, turnoff the car rightaway and turn it back on. youl probably notice that the light will go away. altleast mine does it every time. |
BigSwede
Sarna, XX, Sweden |
Registered on 8/17/2002 |
36 posts |
Posted:1/10/2004 15:21 |
I´ve got a similar problem.
My trucks rear ABS doesn´t function, the previos owner said that it was the aftermarket brakepads that made it disfunktion, The warning light lights up when I turn on the key but when I start up it shuts off, if the reaar ABS doesn´t work as its supposed it should light up all the time..? Right?
Would I get back the ABS function if I switch back to original brakepads?
Would appreciate if anyone had an answer to my question.
Thanx
Bronco XLT -89
Stock 302cui EFI, K&N
AOD
1300+ watts stereo
JVC MP3 cd
New pics!! |
T. Collins
Lakeland, FL, USA |
Registered on 1/15/2004 |
1 post |
Posted:1/15/2004 19:04 |
I have a 1990 bronco with antilock brakes also my warning lite also come's on but it stays on dealer told I needed to replace speed sensor on rear axle housing. Also found out that due to this problem my cruise control will not funtion either. |
TJ Doherty
Loveland, CO, USA |
Registered on 1/21/2004 |
25 posts |
Posted:6/21/2004 07:40 |
It is just a sensor but its not as dramatic as to effect cruise control. I have this problem and my cruise works fine. The problem is that it is a sensor that can be faulted because of little things like dirt. The most it will effect will be braking at very low speeds for the rear breaks. |
