Need advice on dying 302 in 93' Bronco
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 755
BRBUZZ151
• The Wood, XX, USA
• Registered on 12/25/2003
Posted:12/31/2003 15:07
Hey dudes:
I have a stock 93 (Speed density) Bronco with 150k miles, stock E40D trans and 3:55 gears. The engine has held up well through normal daily driving and occassional hunting and trekking. 2 Years ago, I blew a head gasket and glazed #8 cylinder and cracked all the rings. It was the classic white smoke in the exhaust, oh shit she's gonna blow scenario. The bearings were then still in their original coat, engine more or less good and for money's sake, I rebuilt that piston, resurfaced that head and went on about business. Normal HP and torque for 2 years.
Now, I have another leak, although it is intermittent and might be a cracked block or head. (???) I am losing coolant slowly, coolant is backing up into the air box and oil pan shows some peanut buttering of the oil. It won't hold a normal idle and has an occasional miss but it is not smoking white or otherwise.
QUESTION: I know I need a rebuild, but I always wanted to get more torque and HP from a 351W. According to the posts here, swapping in a 351 sounds like a pain in the ass. Also, trying to beef up a SD302 might screw with the computer settings. Please give any and all input on what I should try. (1) Stock 302 (2) Beefed 302 with comp cam, edelbrock or similiar heads and intake, or (3) Dive off into 351 ville. I'm new to Baton Rouge and the local "experts" are a combination of "Hey ya'll watch this" and "cha-ching" so I'll be doing most of the work myself. Thanks.
95CobraR
• Registered on 1/2/2004
• 8 posts
15 Vehicles
Posted:1/6/2004 08:16
You may have blown a head gasket (if you are lucky).
Do you need to keep it emissions legal (keep the speed density)? If so, I'd go with the 302. When you have to rebuild, you can rebuild with a stroker almost as cheap as a stock stroke 302.
If no emissions and no worry about gas mileage, I'd go with the 351 and hang a carb on it.
95 Cobra R
2011 Mustang GT
2019 Mustang Shelby GT350 K1868
15 Year Member
