screaming power steering
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 741
matt talley
• niles, MI, USA
• Registered on 1/6/2004
Posted:1/6/2004 15:20
ok i just replaced the rack and pinion, and power steering pump in my 88 thunderbird turbo coupe but it makes a loud screaming noise when you turn on an idle and just above an idle can someone help me with this
Drew Hardrath
• West Valley, UT, USA
• Registered on 10/20/2003
• 33 posts
Posted:1/18/2004 23:57
Make sure your belt isnt too loose or too tight. It should be no more or no less then 1/4 inch of deflection.
matt talley
• niles, MI, USA
Posted:1/22/2004 06:13
yea that would work but the 88 thunderbird has a spring loaded tenshoner
shayne lepage
• toronto, XX, Canada
• Registered on 2/4/2004
Posted:2/5/2004 17:52
i had the same problem in my 92 mustang,i poured some transmission additive in the power steering and the noise slowly went away slowly.
matt talley
• niles, MI, USA
Posted:2/7/2004 18:49
yea ill try that thanks
Greg Stratmeyer
• Hudson, SD, USA
• Registered on 10/29/2003
• 7 posts
Posted:2/16/2004 21:02
if got an 87 Thunderbird with a 347 in it and i had the same problem so i figured i was low on p\s fluid but i didnt have any at the time so i tryed brake fluid and it solved my problem
