Need help with electrical problem
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1518
Josh Carr
• Alexandria, VA, USA
• Registered on 1/9/2004
Posted:1/9/2004 12:57
Hello all...
I noticed that my truck has a strange buzzing noise coming from under the hood near the driver. I figured it was some sort of pump when I bought the thing so the sound was ignored. Aside from the noise I have a wierd problem with having my lights on and not being able to use my right blinker... The light turns on but doesn't blink. If I turn the lights off the blinker works fine. I also have intermitant issues with the cruise control when the lights are on. Finally I noticed something today as I went off to work. The noise I hear under the hood increases as I turn things on! I turned on my rear defrost and it noticably increased the noise it was making and would decrease when I turned it off. Has anyone had this type of issue? Is there some sort of regulator that might be bad? Thanks in advance for any and all help I can get on this matter.
1989 Ford Bronco 302 AOD EB edition.
__________________
Josh
millpondmonster
• onalaska, WA, USA
• Registered on 4/25/2013
• 0 posts
5 Vehicles
Posted:1/13/2004 02:27
josh the problem with your lights and blikers is very likely a bad ground connection at the one that is not working properly. I am sorry to say it , but this is a common problem with fords. it would be a good idea to clean all the ground connections for your lights and put something on them to give them a protective coat. as far as the "buzzing, that sounds like a voltage regulator or relay. just follow the noise....good luck
Tim Bevers
• Portland, OR, USA
• Registered on 1/20/2004
• 7 posts
3 Vehicles
Posted:1/26/2004 13:01
I am having major grounding problems too, what I need is to know where all of the grounding points are under the dash. I have re-done all of the grounds under the hood that I could find, but beyond that I am just wanting a little more info before I dive under the dash. Thanks in advance.
Tim
