Reid Turner
• Brown City, MI, USA |
• Registered on 1/2/2003 |
• 6 posts |
Posted:4/29/2004 22:30 |
I have been noticing that my gas mileage isn't as good as it should be lately, is there anything else besides a standard tune-up that I should have checked over or done that can make sure everything is working a ok? Thanks |
Posted:5/3/2004 14:58 |
Always start with the airfilter if the engine consumes abnormally.
Bronco XLT -89
Stock 302cui EFI, K&N
AOD
1300+ watts stereo
JVC MP3 cd
New pics!! |
Reid Turner
• 6 posts |
Posted:5/4/2004 21:57 |
i have had a k'n air filter for the past 10,000 miles |
Posted:5/11/2004 18:19 |
have you checked for DTCs yet?
checked plug cables for leakage when firing? (at night, no lights, look for spark leakage along wire path esp on pass side under egr valve where they run clost to the valve and stuff
pulled some plugs to ck gap and condition?
pcv valve changed in last 60k miles?
other checks can be done at more cost & diff.; egr passage in intake man. cleaned in past 60k miles?
vacuum gauge readings?
and so on
96 XL 5.0 E4OD, Man Xfer/Hubs
THANKS to ALL WHO SERVE!
