Posted:6/13/2004 12:12 |
i am looking for a fuel filter housing for a 1986 bronco 302 fuel injected i have been having problems with the truck stalling out while driving on the high way and around town. it is almost like it was out of gas, it also pulsates the idle up and down while at a red light. i have changed both fuel pumps idle control valve and one of the fuel filters. while i was changing the cartridge type fuel filter i noticed there were to spring type valves in the filter housing, but they were just floating around in the housing and did not have any tension on them which i am hoping is the cause for the stalling out and pulsation at idle, as they could get sucked against the hole for the flow of fuel and cause a blockage so i am looking for a new cartridge type fuel filter housing. Any help or advice would be greatly appreciated and if there is still something i am missing that could also cause this problem. thanks |
Posted:6/14/2004 23:03 |
Quote: | i am looking for a fuel filter housing for a 1986 bronco 302 fuel injected i have been having problems with the truck stalling out while driving on the high way and around town. it is almost like it was out of gas, it also pulsates the idle up and down while at a red light. i have changed both fuel pumps idle control valve and one of the fuel filters. while i was changing the cartridge type fuel filter i noticed there were to spring type valves in the filter housing, but they were just floating around in the housing and did not have any tension on them which i am hoping is the cause for the stalling out and pulsation at idle, as they could get sucked against the hole for the flow of fuel and cause a blockage so i am looking for a new cartridge type fuel filter housing. Any help or advice would be greatly appreciated and if there is still something i am missing that could also cause this problem. thanks |
Try http://www.broncograveyard.com for a fuel filter housing.
