427or 428????
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1288
Paula Moore
• Sterling, VA, USA
• Registered on 8/28/2004
Posted:9/8/2004 21:31
Hi can someone tell me witch is a better engine, the 427or 428 it will go in to an Australian xb falcon and what 4speed trans should go behind this engine?
Paula
Glenn N
• Fairfield, CT, USA
• Registered on 9/29/2003
Posted:9/26/2004 06:43
Well they are both very good engines but I'd have to say the 427 has the edge over the 428. Larger bore, crossbolted mains, larger block oil passages etc.... Most run a toploader tranny for a 4 speed. They are far more durable than the older T-10's. G.
Ted E.
• Central Texas, TX, USA
• Registered on 5/25/2003
Posted:12/19/2004 14:17
For a street application, the 428 would be more ideal with it's longer stroke and small bore thus having "more seat in the pants" or torque at the lower commonly driven rpms. If you'd like the best of all worlds, use the 427 block with its larger bore in conjuction with the longer stroke 428 crankshaft for an easily built stroker.
Ted.
427or 428????
