1991 ford explorer Electronic shift 4x4
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1387
Pat Smith
• san antonio, FL, USA
• Registered on 1/9/2005
Posted:1/9/2005 18:37
I just purchased a 91 ford explorer eddie bauer edition with the electronic shift 4wd, and i cannot get it to shift into lowrange, normal range 4wd works, but it didnt at first because the previous owner did not use it often. i was wondering if anyone knows anything about the electric shifting and if they could help me out so I can get the low range working. I think the problem may be that the solinoid is froze up, and if anyone had anyideas of how to unfreeze it that would be awesome. thanks
henry
Subscriber since 1/1/2001
• 2,229 posts
10 Vehicles
Posted:1/9/2005 23:58
henry
Just to make sure...you're putting the transmission into "Neutral" when trying to shift to low-range, right? If not, this would explain why low-range isn't working. Usually, if it shifts into 4x4-hi, low-range will also work flawlessly, provided you are stopped and have the vehicle in neutral.
