1995XLT
San Diego/Escondido, CA, USA |
Registered on 10/29/2006 |
2 posts |
Posted:10/29/2006 19:35 |
New to post but I have read the site for a while now.
I have a 1995 XLT with the 351. Only has 112,000 miles on the motor.
The thing runs awesome and fast on the street and in the trails but when I am going up a large grade the motor bogs down and starts to make a knock sound and even sounds like it's backfiring through the intake.
So far I have changed the plugs, added a K&N filter kit, Flowmaster, Throttle body spacer and a MSD coil.
Like I said, It runs awesome all the time EXCELT for the grades.
This weekend while out in the desert I had it in 4high and in first gear going through some sand and it boged down and started that backfire thing.
anyone have a clue what could cause this? I just dont have any power at low end on grades or off road. When I am going slow and crawling I have a ton.
Stock size tires (31's) and 3.73 gearing.
No check engine light that comes on when this happens.
Someone help me?
Thank you |
1995XLT
2 posts |
Posted:10/29/2006 19:42 |
Also like to add that I have tried putting 91 fuel and also 87 and it does the same thing no matter what gas I put in it. |
countryboy141
Maple Valley, WA, USA |
Registered on 12/27/2007 |
5 posts |
Posted:4/7/2008 09:35 |
HEY JUST A THOUGHT FOR YA TAKE IT IN TO A DEALERSHIP OR A FRD QUICKLANE AND HAVE THEM RUN A POWER INJECTION FLUSH, AND SCOPE AND SCAN YOUR ECU OH AND WHEN WAS THE LAST TIME U HAD YOUR TRANS SERVICED |
grandpagak
Laporte, MN, USA |
Registered on 1/31/2009 |
4 posts |
Posted:1/31/2009 22:10 |
sounds like timing could be the culprit. |
Treader
Chiefland, FL, USA |
Registered on 7/12/2009 |
4 posts |
Posted:7/15/2009 21:32 |
You might want to check your distributor for worn out bearings. I've seen distributor shaft play cause your problem. Just a thought
Treader |
