8 in v 8.75 in axle
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 544
Chris Archuleta
• Tyler, TX, USA
• Registered on 4/29/2003
Posted:4/29/2003 09:15
What diff between the 8.75 and 8 in rear ends in the 78 Granada? Which is stronger? I'm not sure on what to use I have both. It is going in a 36 sedan.
TIA,
Chris
Linny Wingard
• Charlotte, NC, USA
• Registered on 3/16/2003
• 28 posts
Posted:5/7/2003 22:06
The 8" is a smaller version of the 9". Fairly sturdy, with decent aftermarket support. Identified by center section that removes from the front.
The 8.7" has a cover on the back side to access the gears. Not much parts availability. Might also be a 7-1/2" if it's out of a 6cyl.
You can also look for a '57-'59 Galaxie for a 9" in the same width as a Granada if you need something beefier for a big motor.
8 in v 8.75 in axle
