2000 Crown Vic power trunk release, keyless entry, pwr locks
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1070
2000tjg
• houston, TX, USA
• Registered on 3/15/2009
Posted:3/15/2009 14:06
Hello, I own a 2000 Crown Vic and have a couple of electrical issues that recently started and hope someone knows what to check/look for. The power trunk release, wireless entry (using the key fob), power door locks (from any door), and one touch down driver window stopped working. I checked all the fuses under the dash and hood and they are good. I have good power to the door lock and power window switches at the drivers door. Power at the trunk release switch is weak, the test light glow is dim. I checked one ground location by the hood release latch and it's good. I also checked the wires in the trunk for cuts and they seemed good. For grins, I also replaced the key fob battery, no joy.
Thank you
TJG
justin9jf
• Morris, XX, Canada
• Registered on 3/1/2012
Posted:3/1/2012 18:21
did you ever figure it out? I just had the same problem with my 2004...
rtaillon1
• Fayetteville, NC, USA
• Registered on 3/27/2012
Posted:3/27/2012 13:45
I have an issue with my trunk release switch, I guess it would be the same thing you have. I can lock and unlock it, but when I press the button nothing happens. No sounds or anything. I can't pull the door off yet due to the issue I have with the door panel being screwed on with metal screws. But if I figure out my issue I might be able to throw something to you once I get in there. Good luck
