CROWN VICTORIA PROBLEM YEAR 99
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 926
DEEPBLACKWINDOWS
• FRANKFORT, KY, USA
• Registered on 10/15/2009
Posted:10/25/2009 13:06
HELLO I HAVE A 99 CROWN VIC AND IT HAS DEVELOPED A SMALL LEAK OF WATER AND SOMETIMES THE TEMP GAUGE SWINGS TO THE HOT SIDE BUT WHEN YOU PUSH THE EXCELLERATOR TO THE FLOOR IT GOES DOWN THE FAN IS WORKING WHAT COULD IT BE?
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:11/1/2009 17:06
is the car running when you push the throttle to make the temp go down? if so it could be poor water flow due to a restriction like thermostat sticking,radiator clogged or old water pump not pushing water at idle.where is the leak?
circuithatch
• Woodstock, XX, Canada
• Registered on 4/28/2010
• 7 posts
Posted:6/3/2010 08:43
my 01 p71 was doing the same thing for a bit so i swapped to a 180 deg thermostat and its been mint ever since. its a cheap and easy thing to swap.
