porscheman
• allentown, PA, USA |
• Registered on 7/19/2010 |
• 2 posts |
Posted:7/19/2010 15:31 |
I have a 2001 Crown victoria P71, today the turn signals, brake lights, and hazards stopped working. After some research I noticed a faulty fuse in the interior fuse box and replaced it. Now the hazards and brake lights (all three) are working. The turn signals are not. Since the hazards work i know it isn't the bulbs. I know there is a turn signal relay located in a separate box between the steering column and air conditioning unit. Im weary to open it up because it looks like the relay is soldered into the circuitboard? I am not too familiar with these cars yet, and could really use some help!! What should i do/check next?
Ted
'67 Porsche 912
'85.5 Porsche 944
'01 Police Interceptor
'62 Mercedes 220 SEB Convertible |
blwcorp
• Springfield, MO, USA |
• Registered on 10/11/2010 |
• 19 posts |
• 1 Vehicle |
Posted:10/11/2010 15:17 |
Ted, I have the same problem on a 97 P71 and sent the Lighting Control Module out for repair and it did not fix the the turn signal problem. I also removed and cleaned the multi-switch in the steering column. If you find a fix, please let me know. Brian |
