CROWN VIC ENGINE SWAP
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 930
PROCOP
• HOMESTEAD, FL, USA
• Registered on 8/8/2010
• 8 posts
Posted:8/8/2010 09:46
i AM NEEDING TO REPLACE THE ENGINE IN MY 1998 CROWN VIC P71. CAN I REPLACE IT WITH THE ENGINE FROM THE 1997 MERCURY MARQUIS? WILL IT LINK UP, OR WILL I HAVE ELECTRICAL PROBLEMS ETC.......
Posted:8/8/2010 10:41
From everything I've read, there is a possibility. Any mod engine swap should have the same wiring harness as what was with the engine. If you put a 98 in a 96, you need the harness from the 98. This is because of minor changes Ford made within individual models and years. If you are PROFICIENT in dealing with wiring harnesses, you probably could do it. But that can be a lengthy and time-consuming job.
I've done a few swaps and had to make my own harnesses. It ain't fun.
PROCOP
• 8 posts
Posted:8/10/2010 22:01
Thanks for the reply, i plan on using just the block/ heads, just stripping off the intake and injectors and such because i believe ive thrown a rod, so in your opinion, think i could get by with that and still be okey with the 1998 wire harness?
SilkyStylz
• colorado springs, CO, USA
• Registered on 8/28/2010
Posted:8/28/2010 14:32
im doing the opposite swap i have a 97 and am putting a 04 motor in from a decom CVI they changed it from two coil packs to i believe individual coil packs in 98 so that makes me believe youll need more than a harness in pretty sure they programmed the ecu diffrently, they also changed the transmission if you plan on juastusing they block and a heads im almost positive it will work but electrically im almost certain it wont
