1995 marquis trans problem..
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 849
BBRIDER15
• Chicago, IL, USA
• Registered on 9/7/2010
Posted:9/7/2010 13:13
I got a 95 marquis ls with 104,000 miles. Some times when Im driving with foot slightly on the pedal the trans will just slip into neutral.. This happens every now and then. Car shifts fine other wise I can floor it and go from 0-90 with no issues. Took it to autozone for a code scan and only got p1151 o2 sensor code and that was it but im sure thats not causing it. Also the gear shift indecator needle doesnt line up right, reverse is in between park and reverse,
neutral is in between reverse and neutral, and drive is almost on neutral. Any help on this problem?
Posted:9/7/2010 17:32
Sounds like a misalignment of the indicator and the shift detent. If the shifter is locking into place when you put it in Drive, but the indicator is off, you can get used to it. If it isn't locking properly, look for a mechanic.
BBRIDER15
• Chicago, IL, USA
Posted:9/7/2010 18:57
Thanks for your response. could that be the reason it shifts into neutral while driving too?
stamey68
• gastonia, NC, USA
• Registered on 9/26/2010
• 9 posts
Posted:9/26/2010 14:36
i have an 02 that done same thing,go into neutral before overdrive,it was bad clutches..something you can try-drain all fluid including torque converter..put in shutter stop and 1 quart lucas then finish with tranny fluid..maybe this will help.
