97 P71 turn signals are not working
Thread Statistics:     Users to Post: 3   |   Total Posts: 6   |   Total Views: 737
blwcorp
• Springfield, MO, USA
• Registered on 10/11/2010
• 19 posts
Posted:10/11/2010 15:05
Cleaned multi-switch, had the LCM gone through, fuses are all good. Flashers work but high beams do not. airbag warning light flashes but not constantly.
blwcorp
• 19 posts
Posted:10/11/2010 17:27
Got the signals working, but still no high beams. Checking fuses then bulbs.
Posted:10/11/2010 19:47
Sounds to me like a short or broken electrical path. Some of these are a PITA to figure out. I know this isn't much help, but it's so hard to track something like this down.
Posted:10/11/2010 19:48
Anther thing could be the blinker assembly in the steering wheel.
blwcorp
• 19 posts
Posted:10/12/2010 06:53
Yep, found the cut wires at the high beam lamps. Now just have to figure out how to tie them back in. Thanks, Brian
CROWNVICSRULE
• BLOOMINGTON, IN, USA
• Registered on 11/6/2011
Posted:11/6/2011 08:44
I RECENTLY BOUGHT A RETIRED CHICAGO PD 2003 CROWN VIC POLICE INTERCEPTOR AND THE HIGH BEAMS DID NOT WORK.. I REPLACED THE MULTI FUNCTION SWITCH BUT NO HELP. THEN UPON FURTHER INVESTIGATION I FOUND 3 CUT WIRES STUFFED BEHIND THE WINDSHIELD WASHER RESERVOIR..LEADING FROM THE HEADLIGHTS. 2 GREEN AND 1 RED.. ALSO AT THE FIREWALL ( BETWEEN THE MASTER CYLINDER AND THE FENDER ) THERE WAS 3 CUT WIRES.. 2 GREEN AND 1 RED.. ALONG WITH 2 GREY ONES? ( I FIGURE THE GREY ONES WAS FOR A SIREN ! ) I SPLICED THESE GREEN AND RED WIRES BACK TOGETHER AND THEN MY HIGHBEAMS WOULD FLASH LIKE A POLICE CAR .. I FOUND A FLASHER TUCKED UP UNDER THE DASH ON THE DRIVER SIDE LEFT OF THE BRAKE PEDAL.. (EASY TO LOCATE WHILE THE HEADLIGHTS ARE FLASHING) I MADE A JUMPER WIRE WITH 2 TERMINALS GOING INTO 1 AND PLUGGED IT IN WHERE I HAD REMOVED THE FLASHER.. AND MY HIGH BEAMS HAVE WORKED PROPERLY SINCE.. I HOPE THIS HELPS SOMEONE BECAUSE THERE SEEMS TO BE ALOT OF THESE CARS WITH THE SAME PROBLEM
edited 11/6/2011 08:50
