2002 Crown Vic engine crank over but won't start
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 2700
kitwoman53
• Elba, AL, USA
• Registered on 11/5/2010
Posted:11/5/2010 08:35
2002 Crown Vic engine cranks over but won't start. Noid light that is hooked into the injecter wire doesnt blick when engine is cranking over. Fuel pressure reaches 35 pds. Injector wire has 12 v
on it. Appears no signal from computer. Fuel pumb is working. Did all the pressure check . What next? Still won't start.
bdevans
• Fort Smith , AR, USA
• Registered on 11/6/2010
Posted:11/6/2010 17:38
Im having the same problem, let me know if you come up with anything thanks.
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:11/21/2010 05:09
If you have fuel then you need to check for spark. Check the coils out put to the spark plugs if there is none then check the coil input to see if it is getting a signal to spark. If not then track it back to the fuses then the computer.
