2005CrownVicP71
SW Oregon, OR, USA |
Registered on 12/22/2010 |
7 posts |
Posted:12/22/2010 21:37 |
So tonight I was driving my 2005 Ford Crown Vic P71, on a dark road with all my lights on the street had no street lights then after getting to my destination I turned off the lights and car then when I returned I found that the parking lights went on but both the low beams and high beam headlights were not working, I looked over the fuses, but they all tested good, any suggestions?
Thank you, please help me soon with your comments.. |
jwar1127
lauderhill, FL, USA |
Registered on 5/28/2009 |
47 posts |
Posted:12/23/2010 04:14 |
iT COULD BE THE SWITCH ,LIGHTING CONTROL MODULAR OR BOTH BULBS WENT OUT . I WOULD START WITH A LIGHT TESTER AND START CHECKING IN WIRES FROM THE SWITCH TO THE BULB. |
2005CrownVicP71
7 posts |
Posted:12/23/2010 10:40 |
Could this really be, as the car is only 5 years old, I thought maybe a fuse or something simple?? No?? If i take it to a mechanic can they trace it down pretty fast? |
jesse396
prince george, AL, Canada |
Registered on 2/25/2011 |
3 posts |
Posted:2/26/2011 00:42 |
headlight relay in the lcm. just kick it like the rest of us. lcm is right above gas pedal. |
P71John
Chicago, IL, USA |
Registered on 7/12/2010 |
5 posts |
Posted:3/2/2011 14:45 |
LCMS take a crap alot in the vics just hit it with your hand its that black box |
blitzfik
sun lakes, AZ, USA |
Registered on 2/6/2011 |
5 posts |
Posted:3/24/2011 16:11 |
go to crownvic.net...search...03-04 LCM Headlamp relay replacement - by vicvega - Crownvic/net
you can see complete diagrams and instructions.....i had same problem....on my ...04 CV |
chicklang
Jackson, MS, USA |
Registered on 3/23/2012 |
4 posts |
Posted:3/24/2012 01:18 |
Definitely the LCM [lighting control module] and one of its relays. If you can't find the relays, or don't feel comfortable soldering, then you can pull the LCM and send it to Airbags [on eBay] and they will repair it for $53.00 [permanent repair]. Note: car won't come out of park without LCM in place...so, you'll have to wait a few days to use the car. |
