misfire question
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 1236
P71CAM
• miami, FL, USA
• Registered on 6/1/2011
Posted:6/2/2011 18:40
while I was driving yesterday my 2000 P71. Stalled on me and wouldn't start again I replaced the crank shaft sensor , checked fuel pressure and checked spark... NOW HERE'S THE QUESTION what could cause cylinders. 1,4,5,and 8 to all take a shit at the same time??? Somebody please help
wizzard1222
• Ballwin, MO, USA
• Registered on 1/27/2011
• 139 posts
Posted:6/2/2011 20:11
I'm not full aware of the engine on your 2K P71...however the cylinders you mention might be opposites of the timing order (fire stroke vs exhaust stroke)...???
Have you pulled the OBD2 codes....? If you don't have a scanner....go to your best auto parts store that can provide the service for 'free'....
That should give you a 'wealth of code info'.....
Posted:6/3/2011 07:38
With the majority of new cars on the road using OBD II, you have to have a scanner to see what has happened. Or I should say what the "computer" thinks has happened. It is the only way to be able to troubleshoot and fix the problem. Sometimes something as simple as a corroded wire connector will screw-up the computer.
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:6/3/2011 17:50
What do you mean take a shit no spark ?
P71CAM
• miami, FL, USA
Posted:6/8/2011 23:30
i did not pull the codes yet.. lets say the timing chain skipped a tooth or so..what would the symptoms be and what is the worst possible outcome
misfire question
