Crown Victoria Need help trying to figure out my Ac problem and My Headlight problem
Thread Statistics:     Users to Post: 7   |   Total Posts: 8   |   Total Views: 997
JThree17
• indianapolis, IN, USA
• Registered on 7/23/2011
3 Vehicles
Posted:7/23/2011 12:17
I have a 2003 Crown Victoria LX model and i need to know why my air is blowing through my defrost vent, I was wondering if someone could point out where my AC hoses and stuff is under the hood, and My headlights come on when i turn my lights on but they go out when i use my turn signal and i have to pull back and use my bright lights to see at nite any info would be great cause it sux when u have to drive and hold the turnsignal back for brights
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:7/23/2011 14:26
The stuff that switches the vent is under the glove box. If i remember there is lighting control box also.They looking for vacuum tubing off or brokenby the duct switch.
Posted:7/23/2011 16:10
Get a copy of the Haynes Manual for your car, Either buy one or go tot he library and get one there. It will show you were most parts are located at.
Also, try www.fordparts.com for illustrations of parts.
The defroster problem sounds like a busted tubing. And the light s could be from a bad light module.
aceshot18a
• Saucier, MS, USA
• Registered on 5/15/2011
Posted:7/23/2011 16:34
do you have auto climate control? If so there are some air silonoid air switches that the o-rings go out on inside the control. GOOD LUCK!!! $600.00 part at the dealer, I found one on e-bay for $168.00. AGAIN I SAY GOOD LUCK!!!
JThree17
3 Vehicles
Posted:7/24/2011 20:24
Thanx guys
dbmcd
• Los Angeles, CA, USA
• Registered on 10/12/2001
• 69 posts
1 Boat
4 Motorcycles
11 Vehicles
Posted:7/28/2011 20:54
For the headlights pull the LCM lighting control module and open it. There are 4 small black cubes about 5/8" square. These are relays that make a tink sound when they actuate. Get the info. off of them and search the net. You can buy 4 for about $20. You have to solder them in. Not hard just takes patience and know how to solder. I fixed mine and it works great. This is a common problem. Also, you can find a guy on ebay that will take you box and sell you another one. He just replaces these little relays himself. Good luck....Dave
TeddyJames
• Wheaton, IL, USA
• Registered on 8/14/2011
2 Vehicles
Posted:8/14/2011 11:42
Have the same headlight issue with my 2004 Grand Marquis. Local mechanic told me it\\'s the \\"Light Control Module\\" and part is between $500-$600! Ouch! I had to drive home from a band booking, tired as hell, having to hold back on stalk with everyone flashing their brights at me. Getting repaired tomorrow.
chicklang
• Jackson, MS, USA
• Registered on 3/23/2012
Posted:3/24/2012 01:11
Headlight problem can definitely be attributed to LCM [lighting control module] under dash -- just above gas pedal and attached to dash with a bracket. Usually a bad relay that can be replaced, but if you don't feel comfortable soldering, etc., you can pull the module, send it to Airbags [a place available on eBay] and for $53.00, they'll fix it permanently. Note: car will not come out of park while LCM is not installed. Thus, you have to ship off part and wait a few days before car will be usable again.
