low compression on all cylinders
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1388
vickiluver
• atlanta, GA, USA
• Registered on 7/25/2011
Posted:7/25/2011 11:50
I have a 91 Crown Vicotoria with a 5.0 litre engine. I did a compression test on it and all cylinders were reading between 80 and 90 psi. Are the heads gone or the block???
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:7/25/2011 15:35
when you do the compression test you should do it dry and wet . add a little oil through the spark plug hole to seal the rings and see if the compression changes.If it changes then you could have wore rings.If it dosnt you can do a cylinder leak down test to check the valves.
