Factory Mustang Rims on a Crown Vic
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 2159
PaloloP71
• Honolulu, HI, USA
• Registered on 7/11/2011
Posted:7/26/2011 00:34
Sorry to all of you who probably have to answer this question for the new guy, but I dont want to sift through the old forums to find my answer.
I see that any -02 CV needs a spacer for a Mustang rim to fit because of the difference in offset, but if I use a hub-centric spacer of at at least 1.5", will it clear the studs on the hub without cutting? And whats the smallest hub-centric spacer Ican use without cutting?
On a high-mileage vehicle, is it recommended to change the wheel-bearings and studs nefore installing such a big spacer?
Any feedback wold be appreciated!
Posted:7/26/2011 10:25
According to www.crownvic.net at {http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1061930&gonew=1#UNREAD], you shouldn't need a spacer if you use factory wheels. I have a 1997 CVPI and am using Niche 8.5" x 19" with standard 15mm offset (Mustang stock), and they fit beautifully. Just make sure you use a tire that has the same diameter as your stock tires, and everything should be okay.
